Recently purchased new tires and while in the shop I asked them to check the 12 Volt battery. Pick the car up and everything is fine, they give me the print out from the battery test and it says "battery type" as one area the technician has to enter as part of the test procedure. The print out showed type as "flooded", not AGM.
Battery tested fine and they said no need to buy a battery today.
Does that mistake cause false readings for AGM batteries?
THANKS!
THANKS!
