I drive a 2013 Volt with around 48k miles. First 4 years, my actual range was usually 45-48 miles in the summer and 30-38 in winter (depending on how cold). I had started noticing some range loss including when parked right after charging. The biggest concern I had was that occasionally with a full charge driving the same route I always drive for the past 4 years (no hills, no AC, no heat) the range estimate would drop 10 to 15 miles in just the first 2 miles of driving. There was also a "use" of about 2-3 kwh in that same period. Other times after fully charging, the green battery indicator only lit 8 or 9 of the bars. When this would happen the range estimator would show in the low 30's and that's about what I would get for range. There have been no lights or codes shown.
I have taken it in to the dealer twice. The first time, they said the BECM needed updating and they did so under warranty. But the problem persisted same as before. I did some research here and religiously fully discharged the battery every day for two weeks in hopes of resetting the system. My actual range went from 28 the day I got it back from the dealer to 40 a few days later (all city driving 30-40 mph). Then seemed to settle in the low 30's (summer driving with occasional AC use). Anytime the range indicator showed a full 10 bars and around 40 miles estimated, the range would drop to around 25 miles in the first few actual miles driven.
Second time in to the dealer I suggested a reprogram of the HPCM2 and a reset of the battery range as I'd seen on here several times. They said it was up to date but still reprogrammed it at my request and reset as a courtesy to me but they didn't think it would fix the issue. I then got 9 bars on the range indicator for 7 days in a row with estimates around 30. Actual range on complete discharge was mid to upper 30's (except the one day my wife drove it in D and only got 30). Then, the first day it actually showed 10 bars and 39 miles of range it did the same drop to around 29 miles after only 3 miles traveled.
Any other ideas? Should I call GM or just be happy with mid 30's for range in the summertime?
