Basically all you need is a 240 volt dryer cord with a regular 5-15 120 volt receptacle attached to it. You may need a 3-prong or 4- prong cord depending on your outlet type. OK, let’s see what Home Depot has:
Whirlpool 4 ft. 3-Wire 30 Amp Dryer Cord PT220L - The Home Depot
The 4 ft. Dryer Cord has a 3 prong plug and includes an adjustable strain relief bracket. The cord has ring terminal connectors that ensure the cord stays connected. The heavy duty insulation prevents
www.homedepot.com
AC WORKS 15/ 20 Amp 125-Volt NEMA 5-15/20R 3-Prong Industrial Grade Heavy Duty Household Female Connector AS520R - The Home Depot
This AC WORKS brand, solid industrial grade wiring device [AS520R] is made of very durable construction able to withstand impacts, chemicals, and weather. It is a NEMA 5-15R and 5-20R a 15/20 Amp, 125
www.homedepot.com
