There appears to be a rear fuse panel in the Gen 2 just like the Gen 1. Use an "Add-a-circuit" plug to tap a fuse slot that is switched. Then use a dashcam/GPS hard wire kit to connect it. You should be able to hide the wires behind the plastic panels. You'll need to have some extra slack hanging from the hatch so you can open it. You will need to use a ground point for the hardwire kit. This may involve drilling a small screw in to the metal frame.
Hardwire kit: https://www.amazon.com/gp/product/B00S73FE8A
Add-a-circuit plugs: https://www.amazon.com/dp/B01DYQM6EO/
As an example. I've attached a photo of the front panel fuse in the Gen 1. It shows the 'Add-a-circuit' and hardwire kit. It's completely reversible. Just plug the original fuse back in and remove the cables. The only permanent mod will be the ground screw (If you have to create one). But that'll be hidden and will not affect the car in any way.
